engine rebuild
engine rebuild
Post by surf95 on Wed Aug 15, 2012 11:16 am
i have a 1995 toyota surf with the 3.0 vze and i have a pretty bad lifter tap it wasnt bad till i sank it in the water at onna point and now i have really low oil pressure and a little bit of power lose. also when i crank it up there is a bad knock or grinding sound then like 2 seconds later it goes away ive done some research and it looks like it could be the valve train so i can pick up a set of new heads for about 700 bucks online complete with everything while im at it tho im going to replace the water pump and oil pump and all the belts.
question is should i do it myself or just buy the parts and have a shop do it for me.
and i dont really have a place to do it so i will have to ask some friends if i can use their garage.
if i do decide to do it myself would anyone be interested in helping me out?
thanks
Landon
surf95
Re: engine rebuild
Post by Smokey on Thu Aug 16, 2012 7:19 pm
I'd be down to help you out. I've been there right where your at. I had about 55 man hours in replacing everything in my motor when my fan caught my upper radiator hose... lol.
JUNKED: '96 Surf, 3.0 TD, 883 & Top Plate spacer/851's, ES9000 shocks, 1" Body lift, Spidertrax, 315/70R17 Duratracs, Rear Spool, 5% tint, turbo timer, & all kinds of custom fabbed stuff
NEW: Tin-top Jimny, winch, locked F&R, SPOA, Missing link shackles, etc. etc...
Smokey
Smokey
Re: engine rebuild
Post by surf95 on Fri Aug 17, 2012 3:44 am
ok thanks smokey.. you have the blue diesel surf that got stuck in that whole at onna point right.
and do you have some where we can leave my truck and work on it?
landon
surf95
Re: engine rebuild
Post by surf95 on Tue Aug 21, 2012 2:53 am
ok i just ordered the parts to my truck $1600 later hopefully i got everything.
hey smokey do u have a place we can leave my truck to work on it?
surf95
Re: engine rebuild
Post by Smokey on Thu Aug 23, 2012 8:28 am
Yeah, that was my truck back when it was on 35's. lol.
And yeah, I PMed you about it.
Smokey
Smokey
Re: engine rebuild
